This USB 2.0 USB-A to USB-C cable is the perfect solution for connecting a smartphone, tablet, or other device with a USB-C port to a computer with the standard a USB Type-A port up to 3 metres away for USB 2.0 communication. This cable supports a data rate up to 480Mbps for syncing and downloading pictures or uploading new apps, as well as 5 volts and 1 amp of power for device operation and charging. The USB-C connector has a robust design allowing for the connector to be plugged in and un-plugged up to 10,000 times; six times more connection cycles than traditional USB A connectors. Additionally, the USB-C connector is user-friendly has a symmetrical design which is identical on both sides, meaning it does not matter if you plug it in upside-down or right-side-up. It will plug in the first time, every time, whilst preventing damage to the connector port. The colour coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. This cable is designed to support USB 2.0 communication and features and is not able to support USB 3.1 Gen 2 Communication and features.
Black -
Warranty
Lifetime -
Length
3 metre -
USB 2.0 Type-C Connector
Male -
USB 2.0 Type-A Connector
Male
- C2G 3m USB 2.0 USB Type C to USB A Cable M/M - USB C Cable Black - USB-C cable - USB to 24 pin USB-C - 3 m
- USB-C cable
- Technology
- Double shielded
- Molded, sync and charge, nickel plated shell
- Length
- 3 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 24 pin USB-C - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB-C cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 24/30
- Length
- 3 m
- Black
- 103 g
- Connector
- USB / USB 2.0
C2G 3m USB 2.0 USB C to USB A Cable M/M – Black
