The Ultima USB cable optimizes style, quality, and value in a cable specially designed for high performance. Just plug-and-play for USB devices with the mini-b port, and this cable will deliver high speed data transfer up to 480 Mbps. Two 24 AWG and two 28 AWG heavy duty wires provide the proper current to your USB device. Dual foil and braid shielding reduces EMI/RFI interference while twisted pair construction helps reduce crosstalk thus ensuring high speed, error-free data transfer. The sleek design of the molded connectors makes them easy to grip. The metal connector shield helps to meet FCC requirements on EMI/RFI interference, while a solder-to-connector shell and cable braid create an end-to-end shielding solution for a noise-free connection. 24k gold-plated connectors provide maximum corrosion resistance for error-free data transfer. The charcoal gray cable jacket not only matches your case but disappears behind your desk leaving a clean organized look. Finally, an ultra-flexible jacket makes installation easy.
Enhanced durability
The C2G Ultima 3m USB 2.0 A to Mini-B Cable is designed with a gold-plated connector and molded features, ensuring a robust connection that withstands frequent plugging and unplugging. This design choice not only extends the cable's lifespan but also maintains a high-quality signal transmission over time. -
Superior protection
Featuring EMI/RFI protection, the cable is engineered to minimize electromagnetic and radio frequency interference, providing a stable connection for all your devices. The dual foil with braid shielding material further enhances this protection, ensuring that your data transfers remain uninterrupted and secure. -
Universal compatibility
Compliant with USB and USB 2.0 standards, this cable supports a wide range of devices. Its versatility is further emphasized by the inclusion of a 4-pin USB Type-A and a mini-USB Type-B connector, making it suitable for connecting various gadgets, from cameras to mobile phones, without the need for multiple cables.
 - C2G Ultima 3m USB 2.0 A to Mini-B Cable (9.8ft) - USB cable - USB to mini-USB Type B - 3 m
 - USB cable
- Technology
 - Double shielded twisted pair
 - Molded, EMI/RFI protection
- Length
 - 3 m
- Connector
 - 4 pin USB Type A - male
- Connector (Second End)
 - Mini-USB Type B - male
 - USB / USB 2.0
 - Black
 - Limited lifetime warranty
 - USB cable
- Technology
- Shielding Material
 - Dual foil with braid
- Plated Connector
 - Gold
- Length
 - 3 m
 - Black
 - 308 g
- Connector
 - USB / USB 2.0, Plug and Play, FCC
