Ultima HDTV Video Cables from C2G are specifically designed for digital and next generation, high definition analog video applications. The Ultima HDTV Video Cables are constructed from three individually shielded, 75-Ohm coax cables, which provide a performance connection that maximizes color and image. The Ultima HDTV Video Cable meets the rigid standards of everyday use.
Enhanced connectivity
The C2G Ultima HDTV Component Video Breakout Cable offers a seamless connection between devices with its high-quality 15 pin HD D-Sub (HD-15) male connector and three RCA male connectors, ensuring a stable and reliable link for your video components. -
High-quality video transmission
With an impedance of 75 ohm and shielded technology, including foil with copper braid, this video cable is designed to deliver high-quality video without interference, making it suitable for home theater systems and professional setups. -
Durable design
Featuring molded construction and thumbscrews for a secure connection, along with a gold-plated connector for improved signal transmission, the C2G Ultima cable is built for durability and optimum performance, ensuring your setup remains robust.
- C2G Ultima HDTV Component Video Breakout Cable - video cable - component video - 3 m
- Cable
- Video cable - component video
- Technology
- Shielded
- Length
- 3 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- 3 x RCA - male
- Moulded, thumbscrews
- Limited lifetime warranty
- Cable Type
- Video cable
- Interface Supported
- Component video
- Technology
- Shielded
- Shielding Material
- Foil with copper braid
- Impedance
- 75 Ohm
- Length
- 3 m
- Plated Connector
- Gold
- Connector
- 15 pin HD D-Sub (HD-15) - male
- 3 x RCA - male
- RoHS
- Limited warranty - lifetime
