C2G 3m Ultima™ HD15 Male to RCA HDTV Component Video Breakout Cable
Quicklinx: 67VXWS00 Mfr#: 80357
Ultima HDTV Video Cables from C2G are specifically designed for digital and next generation, high definition analog video applications. The Ultima HDTV Video Cables are constructed from three individually shielded, 75-Ohm coax cables, which provide a performance connection that maximizes color and image. The Ultima HDTV Video Cable meets the rigid standards of everyday use.
  • Enhanced connectivity
    The C2G Ultima HDTV Component Video Breakout Cable offers a seamless connection between devices with its high-quality 15 pin HD D-Sub (HD-15) male connector and three RCA male connectors, ensuring a stable and reliable link for your video components.
  • High-quality video transmission
    With an impedance of 75 ohm and shielded technology, including foil with copper braid, this video cable is designed to deliver high-quality video without interference, making it suitable for home theater systems and professional setups.
  • Durable design
    Featuring molded construction and thumbscrews for a secure connection, along with a gold-plated connector for improved signal transmission, the C2G Ultima cable is built for durability and optimum performance, ensuring your setup remains robust.
C2G Ultima HDTV Component Video Breakout Cable - video cable - component video - 3 m
Cable
Video cable - component video
Shielded
Length
3 m
Connector
HD-15 (VGA) - male
Connector (Second End)
3 x RCA - male
Moulded, thumbscrews
Cable Type
Video cable
Interface Supported
Component video
Shielded
Shielding Material
Foil with copper braid
Impedance
75 Ohm
Length
3 m
Plated Connector
Gold
Connector
3 x RCA - male
RoHS
Limited warranty - lifetime
