This Ultima cable optimizes style, quality, and value in a cable specially designed for high performance. Universally designed to work with KVM switches from many leading manufacturers. This cable features separate keyboard, monitor, and mouse cable components combined into one cable that is separated at each end.
The 3-in-1 design keeps your cable area better organized while color-coded connectors make this cable easy to manage.
The VGA component is built from premium coaxial cabling that ensures superior resolution by eliminating ghosting and fuzzy images. Connectors are PC-99 color-coded for easy Plug and Play installation.
- C2G Ultima 3-in-1 Universal - keyboard / video / mouse (KVM) cable - 3 m
- Keyboard / video / mouse (KVM) cable
- Colour-coded connectors
- Length
- 3 m
- Connectors
- 15 pin HD D-Sub (HD-15) - male , 2 x 6 pin mini-DIN (PS/2 style) - male
- Connectors (Second End)
- Charcoal
- Limited lifetime warranty
- Length
- 3 m
- Charcoal
- Connectors
- RoHS
C2G 3m Ultima™ 3-in-1 Universal KVM HD15 VGA M/M Cable
