C2G 3m Ultima™ 3-in-1 Universal KVM HD15 VGA M/M Cable
Quicklinx: 6BJTWS00 Mfr#: 81735
This Ultima cable optimizes style, quality, and value in a cable specially designed for high performance. Universally designed to work with KVM switches from many leading manufacturers. This cable features separate keyboard, monitor, and mouse cable components combined into one cable that is separated at each end.
The 3-in-1 design keeps your cable area better organized while color-coded connectors make this cable easy to manage.
The VGA component is built from premium coaxial cabling that ensures superior resolution by eliminating ghosting and fuzzy images. Connectors are PC-99 color-coded for easy Plug and Play installation.
C2G Ultima 3-in-1 Universal - keyboard / video / mouse (KVM) cable - 3 m
Keyboard / video / mouse (KVM) cable
Colour-coded connectors
Length
3 m
Connectors
15 pin HD D-Sub (HD-15) - male ¦ 2 x 6 pin mini-DIN (PS/2 style) - male
Connectors (Second End)
Charcoal
Length
3 m
Charcoal
Connectors
RoHS
