C2G 3m ST-ST 9/125 OS1 Duplex Singlemode PVC Fibre Optic Cable (LSZH) - Yellow
Quicklinx: 9CBTWS00 Mfr#: 85561
Cost-effective solution that provides high bandwidth and transmission rates over longer distances. With ST to ST termination, this high quality fibre optic patch cable is specifically designed for Gigabit Ethernet applications. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures. This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs. Each cable is 100% optically inspected and tested for insertion loss before you receive it. A pull-proof jacket design surrounds the popular 9/125 Single-mode fibre, immune to electrical interference.
  • High-quality connectivity
    The ST-ST 9/125 OS1 Duplex Singlemode PVC Fiber Optic Cable is designed with a core and cladding diameter of 9 / 125 micron, ensuring high-quality, reliable connectivity for critical network applications.
  • Durable and safe
    Featuring a Low Smoke Zero Halogen (LSZH) jacket, this cable minimizes the amount of toxic and corrosive gas emitted during combustion, making it a safer choice for enclosed spaces.
  • Wide temperature range
    With an operating temperature range from -20°C to 70°C, the cable is built to perform reliably in various environmental conditions, ensuring uninterrupted service.
C2G ST-ST 9/125 OS1 Duplex Singlemode PVC Fiber Optic Cable (LSZH) - network cable - 3 m - yellow
Network cable - OS1
Duplex fibre optic
Type of Fibre Optics
Singlemode
Halogen-free
Length
3 m
Core / Cladding Diameter
9 / 125 micron
Connector
2 x ST single-mode - male
Connector (Second End)
Yellow
Network Cable Type
Network cable - OS1
Duplex fibre optic
Singlemode
Jacket Material
Fibre Qty
2
9 / 125 micron
Halogen-free
Length
3 m
Yellow
Connector
TIA/EIA-455-171A
-20 °C
70 °C
