Experience ULTRA HD (4K) displays with this Select High-Speed HDMI Cable which provides a fast and reliable connection for home theatre or desktop audio video applications requiring high speed HDMI capabilities and video resolutions up to 4K (2160p). This High-Speed HDMI Cable supports the latest HDMI features including Ultra HD, 4K at 50/60 (2160p), up to 32 audio channels and wide angle theatrical 21:9 video aspect ratio and is compatible with any modern Laptop, Chromebook, HDTV or gaming console, including Sony PlayStation 4 (PS4) and Microsoft Xbox ONE. The cable is also backwards compatible with PlayStation 3 (PS3) and Xbox 360. The CL2 rated cable jacket is designed to meet the requirements for in-wall installations. The Ethernet capabilities of the cable allow users to connect multiple Ethernet-enabled HDMI devices through a single Ethernet connection. This fully-functional, high bandwidth cable is tested to perform at industry standards and is backed by a lifetime warranty. Note: Both the source device and display must support a HDMI feature in order to pass that particular feature through this cable.
                HDMI Feature NoteBoth the source device and display must support an HDMI feature in order to pass that feature through this cable
                Multi-Stream AudioSimultaneous delivery of multi-stream audio to multiple users (up to 4)
                Wide Angle SupportSupport for the wide angle theatrical 21:9 video aspect ratio
                Dynamic SynchronizationDynamic synchronization of video and audio streams
                CEC ControlCEC extensions for control of consumer electronics devices through a single control point
                CompatibilityCompatible with both Sony PlayStation 4 (PS4) and MicroSoft XBOX ONE consoles. It's also backwards compatible with PlayStation 3 (PS3) and XBOX 360
                ColourBlack
                WarrantyLifetime
                Connector 1(1) HDMI Male
                Connector 2(1) HDMI Male
- C2G 3m Select High Speed HDMI Cable with Ethernet - 4K - UltraHD - HDMI cable with Ethernet - 3 m
- Cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Length
- 3 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- Limited lifetime warranty
- Designed For
- Dell Inspiron 3847
- Cable Type
- Technology
- Shielded
- 28
- Jacket Material
- PVC
- Shielding Material
- Aluminium foil with braid
- Impedance
- 100 Ohm
- Length
- 3 m
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- UL
- Limited warranty - lifetime
- Designed For
