C2G 3m Mini DisplayPort Male to Single Link DVI-D Male Adapter Cable - White
Quicklinx: 9MS2WS00 Mfr#: 84339
Select:
  • 3m
This adapter cable is an ideal solution for connecting the Mini DisplayPort output of a small laptop or tablet to a computer monitor which accepts a DVI-D input. This cable carries a digital video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
  • Seamless connectivity
    The 3m Mini DisplayPort to Single Link DVI-D Adapter Cable M/M offers a direct connection between your Mini DisplayPort-equipped device and a DVI-D display, enabling high-quality video streaming without the need for additional adapters or converters.
  • High-quality construction
    Crafted with precision, this white adapter cable ensures durability and reliable performance, making it an ideal solution for both home and office environments.
  • Versatile compatibility
    Designed to be compatible with PC, this cable supports a wide range of devices, allowing for flexible usage across different platforms and setups.
C2G 3m Mini DisplayPort to Single Link DVI-D Adapter Cable M/M - Mini DP to DVI - White - DisplayPort cable - 3 m
DisplayPort cable - single link
Length
3 m
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-D - male
White
DisplayPort cable
TMDS Links
Single link
Length
3 m
White
Connector
18+1 pin digital DVI (Single-Link) - male
