C2G 3m Mini DisplayPort Male to Single Link DVI-D Male Adapter Cable - Black
Quicklinx: 9MRZWS00 Mfr#: 84336
Select:
  • 3m
This adapter cable is an ideal solution for connecting the Mini DisplayPort output of a small laptop or tablet to a computer monitor which accepts a DVI-D input. This cable carries a digital video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
  • Seamless connectivity
    The 3m Mini DisplayPort to Single Link DVI-D Adapter Cable M/M offers a direct connection between your Mini DisplayPort-equipped device and a DVI-D display. This enables you to enjoy high-quality video streaming or gaming without the need for an adapter.
  • High-quality construction
    Crafted with precision, this black cable ensures a reliable connection between your devices. Its durable design ensures long-lasting performance, making it an essential accessory for your setup.
C2G 3m Mini DisplayPort to Single Link DVI-D Adapter Cable M/M - Mini DP to DVI - Black - DisplayPort cable - 3 m
DisplayPort cable - single link
Length
3 m
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-D - male
DisplayPort cable
TMDS Links
Single link
Length
3 m
Connector
18+1 pin digital DVI (Single-Link) - male
