This cable is an ideal solution for connecting the Mini DisplayPort output of a small laptop or tablet to a computer monitor which accepts a Mini DisplayPort input. This cable carries a digital audio/video signal. Support of a High Bit Rate (HBR) bandwidth means that this cable can carry up to a 4k resolution. Built to DisplayPort 1.2 standards, this cable meets the requirements of high performance applications.
Seamless connectivity
Experience high-quality, uninterrupted connections with the 3m Mini DisplayPort Cable 4K UHD M/M - White, designed to link your devices with ease. Its compatibility with DisplayPort 1.2 standards ensures you can enjoy 4K video content at ultra-high definition without any compromise. -
Durable design
Crafted for both durability and performance, this cable features robust male connectors on both ends, ensuring a secure and stable connection between your devices. The white cable not only adds a sleek look to your setup but also promises longevity for extensive use.
- C2G 3m Mini DisplayPort Cable 4K UHD M/M - White - DisplayPort cable - 3 m
- DisplayPort cable
- Length
- 3 m
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- White
- Limited lifetime warranty
- DisplayPort cable
- Length
- 3 m
- White
- Connector
- DisplayPort 1.2
