C2G 3m IEEE-1394a FireWire® 4-pin to 4-pin Cable
Quicklinx: 63V4WS00 Mfr#: 81608
IEEE 1394 FireWire cables from C2G provide transfer speeds up to 400 Mbps. Digital video camcorders, scanners, printers, video conferencing cameras and fixed-disk drives can all share a common bus connection to one PC, as well as to each other. With Windows ME or Apple's FireWire Target Disk Mode you can use an IEEE-1394 cable to connect two computers together to allow for file sharing. Use the 6-pin cable to provide power to devices and the 4-pin for non-powered devices.
  • Versatile compatibility
    Designed to bridge the connection gap, this IEEE 1394 cable boasts compatibility with Mac, PC, and Unix systems, ensuring a wide range of devices can communicate seamlessly.
  • High-quality connection
    Featuring male to male connectors on both ends with a 4-pin FireWire interface, this cable is crafted for a reliable, high-speed data transmission experience.
  • Environmentally conscious
    Adhering to RoHS standards, this cable is manufactured with a commitment to environmental responsibility, minimizing the use of hazardous substances in its construction.
C2G - IEEE 1394 cable - 4 PIN FireWire to 4 PIN FireWire - 3 m
IEEE 1394 cable
Molded
Length
3 m
Connector
4 PIN FireWire - male
Connector (Second End)
IEEE 1394
IEEE 1394 cable
Molded
Length
3 m
Connector
IEEE 1394, Plug and Play, RoHS
