C2G 3m IEEE-1284 DB25 M/F Parallel Printer Extension C
Quicklinx: 684NWS00 Mfr#: 81471
High-speed IEEE-1284 compliant cables from C2G ensure you realize the added speed and two way communications offered by your newer printers, HP tape drives, Iomega devices, scanners and more. This advanced technology, which defines high-speed, bi-directional communications between PC and peripheral, requires both high quality connectors and a specialized wire-type to handle the increased data rates.
C2G parallel extension cable - 3 m
Parallel extension cable
Shielded foiled twisted pair (SFTP)
Molded
Length
3 m
Connector
DB-25 - male
Connector (Second End)
DB-25 - female
RoHS
Shielding Material
Foil with braid
Molded
Length
3 m
Connector
25 pin D-Sub (DB-25) - male
25 pin D-Sub (DB-25) - female
IEEE-1284, RoHS
