High-speed IEEE-1284 compliant cables from C2G ensure you realize the added speed and two way communications offered by your newer printers, HP tape drives, Iomega devices, scanners and more. This advanced technology, which defines high-speed, bi-directional communications between PC and peripheral, requires both high quality connectors and a specialized wire-type to handle the increased data rates.
- C2G parallel extension cable - 3 m
- Parallel extension cable
- Technology
- Shielded foiled twisted pair (SFTP)
- Molded
- Length
- 3 m
- Connector
- DB-25 - male
- Connector (Second End)
- DB-25 - female
- RoHS
- Technology
- Shielding Material
- Foil with braid
- Molded
- Length
- 3 m
- Connector
- 25 pin D-Sub (DB-25) - male
- 25 pin D-Sub (DB-25) - female
- IEEE-1284, RoHS
