Replace your overused or misplaced power cable, or just manage your power more efficiently. This handy cable features a UK plug which splits to two female C13 shroud. Simply plug the power cord's male prong into a standard power outlet, and you're ready to power multiple electronic devices. Saves space by eliminating extra cords, and keeps your surge strip and UPS outlets from being blocked by bulky AC transformers. Ideal for use in compact workplaces or home offices where there is limited space for electronic equipment. Plus this heavy duty 17 AWG cord features a fully moulded design for maximum durability and long life. Compatible for digital signage, power transformers, computers, monitors, scanners, printers and other devices that use a 3-pin male shroud (C13), often called a Kettle Lead power connector.
Product Use
Power cord for powering multiple devices with one outlet -
Warranty Details
This product carries a lifetime warranty -
Connector Information
Often referred to as a Kettle Lead power connector
- C2G Power Cord Splitter - power splitter - power CEE 7/7 to power IEC 60320 C13 - 3 m
- Power splitter
- Molded
- Length
- 3 m
- Localisation
- Europe
- Connector
- Power CEE 7/7 - male
- Connector (Second End)
- 2 x power IEC 60320 C13
- Rated Voltage
- AC 250 V
- Black
- Limited lifetime warranty
- Power splitter
- American Wire Gauge (AWG)
- 17
- Rated Voltage
- AC 250 V
- Molded
- Length
- 3 m
- Black
- Localisation
- Europe
- Connector
