C2G 3m European Non-Polarised Power Cord CEE 7/7 - IEC 60320 C7
Quicklinx: 98PSWS00 Mfr#: 80618
Replace your overused or misplaced power cable, or just get some extra cords for convenience. This non-polarized power cord is designed to work with laptops, gaming consoles and other audio/video equipment that uses a 2-slot non-polarized power cord. Plus this heavy duty 18 AWG cord features a fully melded design for maximum durability and long life. The female connector, often called a figure of 8, plugs directly into the device while the male connector plugs into a standard power outlet.
  • Versatile compatibility
    Designed specifically for PCs, this power cord seamlessly integrates with a wide range of computer systems, ensuring a reliable power connection every time.
  • Robust construction
    Featuring an 18 AWG thickness, this power cable is built to deliver efficient power transmission while withstanding the rigors of daily use.
  • Secure connections
    Equipped with a power IEC 60320 C7 connector on one end and a power CEE 7/7 male connector on the other, it ensures a secure and stable connection to your power source and device.
C2G Non-Polarised Power Cord - power cable - power IEC 60320 C7 to power CEE 7/7 - 3 m
Power cable
Molded
Length
3 m
Europe
Connector
Power IEC 60320 C7
Connector (Second End)
Power CEE 7/7 - male
Rated Voltage
AC 250 V
Power cable
American Wire Gauge (AWG)
18
Rated Voltage
AC 250 V
Molded
Length
3 m
Europe
Connector
Power IEC 60320 C7
