Brand
C2G 3M DVI I M/M SINGLE LINK VIDEO CBL
Quicklinx: 63QHWS00 Mfr#: 81201
This precision-engineered cable is fully compliant with the DVI standard defined by DDWG (Digital Display Working Group). The DVI-I single link configuration provides enough bandwidth for resolutions up to 1600 x 1200 pixels and allows high speed transmission up to 4.95 Gbps. Three analogue 30 AWG coaxial lines enable high speed analogue transmission.
C2G DVI cable - 3 m
DVI cable - single link
Colour-coded connectors
Length
3 m
Connector
DVI-I - male
Connector (Second End)
DVI-I - male
PC 99, RoHS
DVI cable
American Wire Gauge (AWG)
28/30
TMDS Links
Single link
Plated Connector
Gold
Length
3 m
Connector
18+5 pin combined DVI (Single-Link) - male
PC 99, RoHS
