C2G 3m DVI-A Male to HD15 VGA Male Analogue Video Cable
Quicklinx: 63V9WS00 Mfr#: 81207
Digital Visual Interface (DVI) is the standard interface for high-performance connection between desktop PCs and flat panel displays, CRT displays, projectors, and HDTV. This analogue video cable is fully compliant with the DVI standard defined by DDWG (Digital Display Working Group). Three analogue 30 AWG coaxial lines enable high speed analogue transmission
C2G VGA cable - 3 m
VGA cable
Colour-coded connectors
Length
3 m
Connector
DVI-A - male
Connector (Second End)
HD-15 (VGA) - male
PC 99, RoHS
VGA cable
American Wire Gauge (AWG)
28/30
Plated Connector
Gold
Length
3 m
Connector
12+5 pin analogue DVI - male
PC 99, RoHS
