C2G 3m DisplayPort Male to VGA Male Adapter Cable - Black
Quicklinx: 9MRWWS00 Mfr#: 84333
Select:
This adapter cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a VGA input. This cable carries an analogue video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
  • Seamless connectivity
    The DisplayPort Male to VGA Male Adapter Cable from C2G offers a direct and robust connection between your DisplayPort-equipped device and a VGA input monitor. This ensures a seamless and high-quality video experience without the need for additional adapters or converters.
  • Versatile compatibility
    Designed to meet the needs of PC users, this adapter cable is compatible with a wide range of devices. Whether you're connecting a laptop to a projector or a desktop to a monitor, the cable's compatibility ensures a reliable connection across various platforms.
  • High-quality construction
    Crafted with precision, the cable features a 20-pin DisplayPort male connector on one end and a 15-pin HD D-Sub (HD-15) male connector on the other. This design ensures a secure connection and delivers a high-quality video signal for your presentations, movies, and more.
C2G DisplayPort Male to VGA Male Adapter Cable - DisplayPort cable - 3 m
DisplayPort cable
Length
3 m
Connector
DisplayPort - male
Connector (Second End)
HD-15 (VGA) - male
DisplayPort cable
Length
3 m
Connector
20 pin DisplayPort - male
