C2G 3m DisplayPort Cable with Latches M/M - Black
Quicklinx: 9MS5WS00 Mfr#: 84402
Length: 3m
£14.52 ex VAT
£17.42 inc VAT
This cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a DisplayPort input. This cable carries a digital audio/video signal and the connectors feature latches which secure the cable in the port. Support of a High Bit Rate (HBR) bandwidth means that this cable can carry up to a 4k resolution. Built to DisplayPort 1.2 standards, this cable meets the requirements of high performance applications.
  • High compatibility
    Designed to meet the needs of a wide range of PC setups, this DisplayPort cable ensures seamless connectivity and integration with any PC, enhancing the user experience by providing reliable, high-quality connections.
  • Secure connection
    Featuring latches on the connectors, this cable offers a secure connection to prevent accidental disconnections. This design ensures a stable and uninterrupted signal, making it ideal for critical presentations and entertainment setups.
C2G 3m DisplayPort Cable with Latches 8K UHD M/M - 4K - Black - DisplayPort cable - 3 m
DisplayPort cable
Latched
Length
3 m
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
DisplayPort cable
Latched
Length
3 m
Connector
20 pin DisplayPort - male
DisplayPort 1.2
Length: 3m
Brand: C2G
