Don't sacrifice convenience when determining where to place your hardware. A DB9 F/F cable can convert an existing DB9 M/M cable to a DB9 M/F cable for added flexibility. Each cable comes fully shielded to prevent unwanted EMI/RFI interference, and the fully snagless cable design delivers excellent strain relief. Connector thumbscrews provide a quick and easy connection every time. All lines are wired straight through.
Reliable connectivity
Experience dependable and secure connections with the C2G serial cable, featuring shielded technology that ensures your data transfers remain uninterrupted and safe from external interferences. -
Versatile compatibility
Designed to meet the needs of PC users, this serial cable boasts a universal 9-pin D-Sub (DB-9) female connector on both ends, making it highly compatible with a wide range of devices. -
Eco-friendly choice
Committed to environmental responsibility, the C2G serial cable adheres to RoHS compliant standards, ensuring that it is manufactured with restricted hazardous materials for a safer planet.
- C2G - serial cable - DB-9 to DB-9 - 3 m
- Serial cable
- Technology
- Shielded
- Molded, thumbscrews
- Length
- 3 m
- Connector
- 9 pin D-Sub (DB-9) - female
- Connector (Second End)
- Black
- Serial cable
- Technology
- Shielded
- Length
- 3 m
- Black
- Connector
- RoHS
