Don't sacrifice convenience when determining where to place your hardware. A DB9 F/F cable can convert an existing DB9 M/M cable to a DB9 M/F cable for added flexibility. Each cable comes fully shielded to prevent unwanted EMI/RFI interference, and the fully snagless cable design delivers excellent strain relief. Connector thumbscrews provide a quick and easy connection every time. All lines are wired straight through.
- C2G - serial cable - DB-9 to DB-9 - 3 m
- Serial cable
- Technology
- Shielded
- Molded, thumbscrews
- Length
- 3 m
- Connector
- 9 pin D-Sub (DB-9) - female
- Connector (Second End)
- Beige
- Serial cable
- Technology
- Shielded
- Length
- 3 m
- Beige
- Connector
- RoHS
