For fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels with a LSZH outer jacket. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily colour-code your network installation. Each cable is individually labelled with the length for ease of use.
Connector 1: (1) RJ-45 Male.
Connector 2: (1) RJ-45 Male.
Enhanced connectivity
Featuring gold-plated RJ-45 connectors, this CAT 6 patch cable ensures a secure and corrosion-resistant connection, enhancing signal quality for reliable network performance. -
Durable design
Constructed with a Low Smoke Zero Halogen (LSZH) jacket, the cable minimizes the amount of toxic and corrosive gas emitted during combustion. This makes it a safer choice for enclosed spaces. -
Improved network integrity
With minimized Near-End Crosstalk (NEXT) and reduced structural return loss (SRL), this cable is designed to provide a clearer signal by reducing interference, ensuring high-speed data transmission without loss. -
Easy handling
The snagless, booted design with a latching clip makes handling and installation easier, preventing cable snags and ensuring a secure connection at all times.
- C2G patch cable - 3 m - green
- Patch cable - CAT 6
- Technology
- Wires per Cable
- 8 wires
- Booted, snagless, minimised Near-End Crosstalk (NEXT), reduced structural return loss (SRL), latching clip
- Length
- 3 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Green
- Limited lifetime warranty
- Network Cable Type
- Technology
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 3 m
- 124 g
- Green
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, TIA/EIA-568-B.2
