For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
High-quality connectivity
The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a 24 American Wire Gauge (AWG) and a durable PVC jacket, ensuring a reliable connection and long-lasting performance. -
Enhanced performance
With a tested frequency of up to 550 MHz, this patch cable supports high-speed data transfer rates, making it ideal for various networking applications. -
Universal compatibility
Featuring RJ-45 male connectors on both ends and adhering to the T568B wiring scheme, this cable is compatible with a wide range of devices, ensuring seamless integration into any setup.
- C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 3 m - purple
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded
- Length
- 3 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Purple
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 3 m
- Purple
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 550 MHz
