C2G 3m Cat6 550 MHz Snagless Patch Cable - Purple
Quicklinx: 6BV5WS00 Mfr#: 83634
Length: 3m
Colour: Purple
31 left in stock
£2.99 ex VAT
£3.58 inc VAT
For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
  • High-quality connectivity
    The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a 24 American Wire Gauge (AWG) and a durable PVC jacket, ensuring a reliable connection and long-lasting performance.
  • Enhanced performance
    With a tested frequency of up to 550 MHz, this patch cable supports high-speed data transfer rates, making it ideal for various networking applications.
  • Universal compatibility
    Featuring RJ-45 male connectors on both ends and adhering to the T568B wiring scheme, this cable is compatible with a wide range of devices, ensuring seamless integration into any setup.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 3 m - purple
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Purple
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
24
Plated Connector
Gold
Length
3 m
Purple
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
Length: 3m
Colour: Purple
Brand: C2G
Stock Status: While stocks last
Stock Status: Clearance
