C2G 3m Cat6 550 MHz Snagless Patch Cable - Brown
Quicklinx: 6BVJWS00 Mfr#: 83648
For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
  • High-speed connectivity
    Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures optimal performance for your networking needs, whether at home or in the office.
  • Durable design
    Constructed with a PVC jacket and featuring gold-plated connectors, this patch cable is built for longevity and reliable connectivity. The 24 AWG American Wire Gauge ensures a durable, high-quality connection that stands the test of time.
  • Universal compatibility
    With T568B wiring scheme and RJ-45 connectors, this cable is compatible with a wide range of devices and networks. It's designed to meet the requirements of PC environments, making it a versatile choice for various networking setups.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 3 m - brown
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Brown
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Gold
Length
3 m
Brown
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
