C2G 3m Cat6 550 MHz Snagless Patch Cable - Black
Quicklinx: 6BQ7WS00 Mfr#: 83409
Length: 3m
Colour: Black
£3.33 ex VAT
£3.99 inc VAT
For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
  • High-speed connectivity
    Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures high-speed data transmission for your computing needs, making it a suitable choice for both home and office environments.
  • Durable design
    Constructed with a 24 American Wire Gauge (AWG) and a robust PVC jacket, this patch cable is built for durability and long-term use. The gold-plated RJ-45 connectors provide a reliable connection and resist corrosion, ensuring your network setup remains intact.
  • Universal compatibility
    The Cat6 Booted Unshielded (UTP) Network Patch Cable adheres to the T568B wiring scheme and is compatible with PC systems. This universal compatibility ensures a hassle-free setup for a wide range of network configurations.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 3 m - black
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
24
Plated Connector
Gold
Length
3 m
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
Length: 3m
Colour: Black
Brand: C2G
