Cables To Go's Cat6 crossover cables are perfect for distributing data, voice, video and connecting network switches and hubs without an uplink port to other switches and hubs. These 550MHz rated patch cables ensure that you always have the necessary throughput to handle bandwidth-intensive applications. Note:These cables are for 10/100 ethernet only and will not work for gigabit ethernet as only two pairs of this cable are crossed. Our new moulded, snag-free "clip" prevents unwanted cable snags during installation and doesn't impair the ability to insert and remove the connector from the port. It also provides extraordinary strain-relief, so that the cable is not damaged even when pulled excessively.
Enhanced connectivity
The Cat6 Booted Unshielded (UTP) Crossover Patch Cable by C2G is designed to connect two devices directly, such as computers to computers, ensuring reliable connectivity and improved network performance. With its T568B wiring scheme and gold-plated RJ-45 connectors, this cable provides a secure and corrosion-resistant connection. -
High-speed performance
Supporting frequencies up to 550 MHz, this crossover cable is perfect for high-speed data transfer and streaming applications. The CAT 6 rating ensures that the cable can handle bandwidth-intensive tasks, making it suitable for gaming, streaming, and network applications that require high-speed data transmission. -
Durable design
Constructed with a 24 American Wire Gauge (AWG) and a PVC jacket, the cable is built to last. It's designed to withstand the rigors of daily use, ensuring a long-lasting, reliable connection for all your networking needs.
- C2G Cat6 Booted Unshielded (UTP) Crossover Patch Cable - crossover cable - 3 m - red
- Crossover cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded
- Length
- 3 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Red
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 3 m
- Red
- Connector
- RJ-45 - male
- RJ-45 - male
- Up to 550 MHz
