Perfect for your home office or a large installation project, Enhanced Cat5E 350MHz Snagless Patch Cables from C2G distribute data, voice and video. These cables handle bandwidth intensive applications up to 350MHz and meet all Cat5E TIA/EIA standards. The molded, snag-free boot prevents unwanted cable snags during installation and provides extra strain-relief.
High-quality connectivity
The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a high-quality PVC jacket and gold-plated connectors to ensure reliable connectivity and durability. Its American Wire Gauge (AWG) of 24 supports efficient data transmission, making it an ideal choice for various networking requirements. -
Enhanced performance
With a tested frequency of up to 350 MHz, this patch cable ensures enhanced performance for your network. The T568B wiring scheme and the presence of 4 pairs per cable ensure that your connection remains stable and strong, providing you with a seamless networking experience. -
Universal compatibility
Designed to be compatible with PCs, this network patch cable features male RJ-45 connectors on both ends, making it versatile for connecting a wide range of devices. Its compliance with RoHS standards also ensures that it meets global regulatory requirements, making it a safe and environmentally friendly choice.
- C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 3 m - grey
- Patch cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Molded, snagless, stranded
- Length
- 3 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Grey
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 3 m
- Grey
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 350 MHz
