This Cat5e network crossover patch cable is an ideal solution for connecting two computer to share files or data. The crossed pin configuration allows two computers to be connected peer-to-peer without the need for a hub or switch. This cable may also be used to connect network switches and hubs without an uplink port to other switches and hubs. This cable is constructed to meet all Cat5e TIA/EIA standards, and has been designed to drastically reduce both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality cable and a shortened body plug, this design minimizes Near-End Crosstalk (NEXT) levels.
Enhanced connectivity
The Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable is designed to connect two devices directly, such as computers, allowing for seamless file transfer and data sharing without the need for a network switch or hub. -
High-quality performance
With a tested frequency of up to 350 MHz, this cable ensures high-speed data transmission and reliability for critical network applications. The use of 24 AWG wire within the cable aids in reducing resistance, thereby supporting faster data transfer rates. -
Durable design
Featuring a PVC jacket material, the cable is built to withstand rigorous or harsh environments, ensuring longevity and durability. The gold-plated connectors also provide corrosion resistance and maintain a reliable connection. -
Universal compatibility
Designed to be compatible with PCs, this crossover cable uses the T568B wiring scheme, making it versatile for various networking setups and ensuring easy integration into existing networks.
 - C2G Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable - crossover cable - 3 m - red
 - Crossover cable - CAT 5e
- Technology
- Wiring Scheme
 - T568B
- Wires per Cable
 - 8 wires
 - Stranded, uniboot
- Length
 - 3 m
- Connector
 - RJ-45 - male
- Connector (Second End)
 - RJ-45 - male
 - Red
- Network Cable Type
- Technology
- Wiring Scheme
 - T568B
- Jacket Material
 - PVC
- American Wire Gauge (AWG)
 - 24
- Wires per Cable
 - 8 wires
- Pairs per Cable
 - 4 pairs
- Plated Connector
 - Gold
 - Stranded, uniboot
- Length
 - 3 m
 - Red
- Connector
 - RJ-45 - male
 - RJ-45 - male
 - Up to 350 MHz
