For voice/data/video distribution, this cable will handle bandwidth-intensive applications. Meets all Cat5E TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL).
Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
Constructed from high-quality cable and a shortened body plug, this design minimizes Near-End Crosstalk (NEXT) levels.
High-quality connectivity
The Cat5e Non-Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its high-performance capabilities. Tested to support frequencies up to 350 MHz, this cable facilitates high-speed data transmission without interference. The use of 24 AWG wire within a durable PVC jacket further enhances signal quality, making it ideal for various networking environments. -
Enhanced durability
Featuring gold-plated connectors that resist corrosion, the Cat5e Network Patch Cable ensures a secure connection and prolonged lifespan. The meticulous wiring scheme of T568B and the presence of 8 wires per cable ensure consistent performance and minimal signal loss, making it a dependable choice for both home and office applications. -
Universal compatibility
Designed to meet the RoHS compliance standards, this patch cable is compatible with PCs and supports a wide range of devices. The male RJ-45 connectors on both ends provide a seamless connection to a variety of networking equipment, ensuring a versatile solution for your connectivity needs.
 - C2G Cat5e Non-Booted Unshielded (UTP) Network Patch Cable - patch cable - 3 m - white
 - Patch cable - CAT 5e
- Technology
- Wiring Scheme
 - T568B
- Wires per Cable
 - 8 wires
 - Stranded, uniboot
- Length
 - 3 m
- Connector
 - RJ-45 - male
- Connector (Second End)
 - RJ-45 - male
 - White
- Network Cable Type
- Technology
- Wiring Scheme
 - T568B
- Jacket Material
 - PVC
- American Wire Gauge (AWG)
 - 24
- Wires per Cable
 - 8 wires
- Pairs per Cable
 - 4 pairs
- Plated Connector
 - Gold
 - Stranded, uniboot
- Length
 - 3 m
 - White
- Connector
 - RJ-45 - male
 - RJ-45 - male
 - RoHS - up to 350 MHz
