C2G 3m Cat5E 350 MHz Assembled Patch Cable - Grey
Quicklinx: 69PXWS00 Mfr#: 83004
Perfect for your home office or a large installation project, Enhanced Cat5E 350MHz Assembled Patch Cables from C2G distribute data, voice and video over today's advanced fast Ethernet and gigabit computer networks. These cables will handle bandwidth intensive applications up to 350MHz and beyond.
  • High-quality connectivity
    The Cat5e Non-Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its high-performance capabilities. Tested up to 350 MHz, this cable is designed to meet the demands of both residential and commercial networking needs.
  • Durable design
    Featuring a PVC jacket material and 24 American Wire Gauge (AWG) thickness, this patch cable is built for durability and long-term use. The gold-plated connectors provide a secure connection and resist corrosion, ensuring optimal signal quality.
  • Universal compatibility
    Designed with T568B wiring scheme and RJ-45 connectors, this network patch cable is compatible with a wide range of devices and networks. It's an ideal choice for connecting PCs and other devices in a network environment.
C2G Cat5e Non-Booted Unshielded (UTP) Network Patch Cable - patch cable - 3 m - grey
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Stranded, uniboot
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Stranded, uniboot
Length
3 m
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
