C2G 3m 75Ohm BNC Cable
Quicklinx: 67W4WS00 Mfr#: 80367
High quality 75-ohm BNC cables from C2G are ideal for video applications including CCTV, broadcast, studio, boardroom presentation, home cinema, etc. It is manufactured from coax cable and nickel plated BNC connectors. A molded PVC strain relief protects the cable from wear over time.
C2G video cable - 3 m
Cable
Video cable
Double shielded coaxial
American Wire Gauge (AWG)
22
Length
3 m
Connector
BNC - male
Connector (Second End)
BNC - male
RG-59
Moulded
Cable Type
Video cable
22
Jacket Material
PVC
Shielding Material
Foil with copper braid
Impedance
75 Ohm
RG-59
Length
3 m
Plated Connector
Nickel
Moulded
Connector
BNC - male
BNC - male
RoHS
