C2G 3m (10ft) USB C Cable M/M - USB 2.0 (5A) - Black
Quicklinx: DWR2WS00 Mfr#: 88829
Length: 3m
£17.77 ex VAT
£21.32 inc VAT
The USB-C to C 2.0 Male to Male Cable is the perfect solution for connecting two standard USB Type C enabled devices or accessories up to 10ft apart for fast charging and high-speed data transfer. This one-cable solution ensures that your USB-C equipped Chromebook, laptop, smartphone or tablet is fully charged and ready to go with the 5A charging output, whilst simultaneously transferring photos, music or data at speeds up to 480 Mbps. 5A of power delivery allows you to charge your mobile devices at even faster rates than with a standard USB 2.0 Cable - making it the perfect solution when on the move. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port.
  • Colour
  • Connector 1
    (1) USB-C Male
  • Connector 2
    (1) USB-C Male
  • Warranty
    3 years
C2G 3m (10ft) USB C Cable - USB 2.0 (5A) - M/M USB Type C Cable - Black - USB-C cable - 24 pin USB-C to 24 pin USB-C - 3 m
USB-C cable
Sync and charge
Length
3 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Current
5 A
USB / USB 2.0
3-year warranty
USB-C cable
Rated Current
5 A
Plated Connector
Nickel
Sync and charge
Length
3 m
Connector
24 pin USB-C - male
24 pin USB-C - male
USB / USB 2.0, RoHS 2 (2011/65/EU)
3-year warranty
Length: 3m
Brand: C2G
