C2G 3ft Google Nexus Charge and Sync Cable
Quicklinx: 9Y4TWS00 Mfr#: 81712
Easily charge and sync your Google Nexus tablet. This cable makes it easy to transfer videos, photos, e-books or other content to or from the tablet. It is perfect as a replacement for a lost cable or convenient as a spare when traveling. There are no drivers or additional software to install – simply plug in and enjoy dual charge and sync functionality. The 3ft length provides the right amount of clearance to place your Nexus in a secure location while charging or syncing and is compatible with both PC and Mac. Performance is guaranteed through a lifetime warranty.
  • Connector 1
    (1) USB-A Male
  • Connector 2
    (1) USB Micro-B Male
  • Warranty
    Lifetime warranty
C2G Google Nexus Charge and Sync Cable - charging / data cable - 91.4 cm
Cable
Charging / data cable
Length
91.4 cm
Connector
Micro-USB Type B - male
Connector (Second End)
USB - male
Sync and charge
Cable Type
Length
91.4 cm
Recommended Use
Tablet
Sync and charge
Connector
5 pin Micro-USB Type B - male
4 pin USB Type A - male
Limited warranty - lifetime
