C2G 3ft Google Nexus Charge and Sync Cable
Quicklinx: 9Y4TWS00 Mfr#: 81712
Easily charge and sync your Google Nexus tablet. This cable makes it easy to transfer videos, photos, e-books or other content to or from the tablet. It is perfect as a replacement for a lost cable or convenient as a spare when traveling. There are no drivers or additional software to install – simply plug in and enjoy dual charge and sync functionality. The 3ft length provides the right amount of clearance to place your Nexus in a secure location while charging or syncing and is compatible with both PC and Mac. Performance is guaranteed through a lifetime warranty.
  • Efficient charging and syncing
    Designed specifically for tablets, this Google Nexus Charge and Sync Cable by C2G ensures your device remains powered up and synchronized with your digital world. The cable facilitates quick charging and efficient data transfer, making it an essential accessory for tablet users.
  • Durable design
    Featuring a robust construction with a 5-pin Micro-USB Type-B connector on one end and a 4-pin USB Type-A connector on the other, this cable is built to withstand the rigors of daily use. Its durability ensures a reliable connection between your tablet and other devices, providing peace of mind.
  • Versatile connectivity
    With male connectors on both ends, this cable offers versatile connectivity options. It supports USB interface for universal compatibility, making it a convenient choice for connecting your tablet to a wide range of devices for charging and data transfer.
C2G Google Nexus Charge and Sync Cable - charging / data cable - 91.4 cm
Cable
Charging / data cable
Length
91.4 cm
Connector
Micro-USB Type B - male
Connector (Second End)
USB - male
Sync and charge
Cable Type
Length
91.4 cm
Recommended Use
Tablet
Sync and charge
Connector
5 pin Micro-USB Type B - male
4 pin USB Type A - male
Limited warranty - lifetime
