C2G 30m ST-ST 9/125 OS1 Duplex Singlemode PVC Fibre Optic Cable (LSZH) - Yellow
Quicklinx: 9CCCWS00 Mfr#: 85567
Cost-effective solution that provides high bandwidth and transmission rates over longer distances. With ST to ST termination, this high quality fibre optic patch cable is specifically designed for Gigabit Ethernet applications. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures. This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs. Each cable is 100% optically inspected and tested for insertion loss before you receive it. A pull-proof jacket design surrounds the popular 9/125 Single-mode fibre, immune to electrical interference.
  • Enhanced durability
    Featuring a Low Smoke Zero Halogen (LSZH) jacket, this fiber optic cable is designed for environments where safety and durability are important. The LSZH material ensures minimal toxic and corrosive gas emission in case of fire, making it a safer choice for crowded spaces.
  • Reliable connectivity
    Equipped with ST single-mode connectors on both ends, this cable ensures a reliable and high-quality connection for your network. The duplex configuration allows for simultaneous, bidirectional transmission, enhancing your network's efficiency.
  • Optimal performance
    With a core and cladding diameter of 9 / 125 micron, this singlemode fiber optic cable is engineered for long-distance, high-bandwidth data transmission. Its compliance with OS1 standards ensures optimal performance and compatibility with a wide range of networking equipment.
C2G ST-ST 9/125 OS1 Duplex Singlemode PVC Fiber Optic Cable (LSZH) - network cable - 30 m - yellow
Network cable - OS1
Duplex fibre optic
Type of Fibre Optics
Singlemode
Halogen-free
Length
30 m
Core / Cladding Diameter
9 / 125 micron
Connector
2 x ST single-mode - male
Connector (Second End)
Yellow
Network Cable Type
Network cable - OS1
Duplex fibre optic
Singlemode
Jacket Material
Fibre Qty
2
9 / 125 micron
Halogen-free
Length
30 m
Yellow
Connector
TIA/EIA-455-171A
-20 °C
70 °C
