Go the distance without ghosting and signal distortion. Constructed from premium grade composite coaxial and twisted pair shielded cables, this ultra-premium monitor cable ensures crisp, distortion-free video so you have maximum monitor positioning flexibility. Uses three internal coax lines for red, green and blue. Ferrited to protect against EMI/RFI interference, this double-shielded cable consists of 125% foil shielding and 90% tinned copper braid shielding. Use it for video projectors, video splitters, KVM switches within video presentations, classroom environments, POS devices, server rooms, etc. Will accommodate cable runs up to 100 feet without a booster (in most cases).
- C2G Pro Series UXGA - VGA cable - 30 m
- VGA cable
- Technology
- Double shielded coaxial
- Length
- 30 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- RoHS
- VGA cable
- Technology
- Shielding Material
- Foil with tinned copper braid
- Length
- 30 m
- Connector
- 15 pin HD D-Sub (HD-15) - male
- RoHS
