With LC to LC termination, this high-quality fiber optic patch cable is specifically designed for fast ethernet, fibre channel, Infiniband, ATM and gigabit ethernet applications. The small LC connectors satisfy the need for higher port density both in the telecom room and the work area, and offer twice the port density of traditional SC and ST fiber connectors. The LC connector with its RJ-style latch clip design is easy to engage and disengage, and gives each connection greater durability in resisting pulls, strains, snags, and impacts during cabling installs and maintenance.
- C2G patch cable - 30 m
- Patch cable
- Technology
- Fibre optic
- Type of Fibre Optics
- Multimode
- Latching connectors
- Length
- 30 m
- Core / Cladding Diameter
- 62.5 / 125 micron
- Connector
- 2 x LC multi-mode - male
- Connector (Second End)
- Network Cable Type
- Patch cable
- Technology
- Fibre optic
- Multimode
- Fibre Qty
- 2
- 62.5 / 125 micron
- Length
- 30 m
- Connector
- RoHS
