C2G 30m DB25 M/M Cable
Quicklinx: 682DWS00 Mfr#: 81395
All 25 lines are wired straight through pin-to-pin for ease of compatibility. Each cable is foil shielded for EMI/RFI protection, and is available fully snagless with thumbscrew connectors for a fast, easy connection every time.
  • Enhanced connectivity
    Experience seamless and reliable connectivity with the C2G serial/parallel cable, designed to link your devices with ease. Its dual functionality supports both serial and parallel interfaces, making it a versatile choice for connecting a wide range of peripherals.
  • Durable design
    Constructed with shielded technology, this cable ensures superior signal integrity and reduces electromagnetic interference. The robust build quality ensures a long-lasting connection between devices, enhancing your workflow without compromise.
  • Universal compatibility
    Designed to meet the needs of PC users, the cable features a 25 pin D-Sub (DB-25) male connector on both ends, offering broad compatibility with various devices. This ensures a reliable connection to printers, scanners, and other essential peripherals.
C2G - serial / parallel cable - DB-25 to DB-25 - 30 m
Serial / parallel cable
Shielded
Molded, thumbscrews
Length
30 m
Connector
25 pin D-Sub (DB-25) - male
Connector (Second End)
Shielded
Molded, thumbscrews
Length
30 m
Connector
RoHS
