C2G 30m DB25 M/F Extension Cable
Quicklinx: 682PWS00 Mfr#: 81404
Easily extend your cables at a lower cost than buying a new cable. All 25 lines are wired straight through pin-to-pin for ease of compatibility. Each cable is foil shielded for EMI/RFI protection, and is available fully snagless with thumbscrew connectors for a fast, easy connection every time.
  • Enhanced connectivity
    This extension cable is expertly designed to extend the reach of your serial and parallel devices, ensuring seamless connectivity and communication between devices.
  • Robust construction
    Featuring a shielded design, this cable provides superior protection against electromagnetic interference, ensuring reliable data transmission even in environments with significant electronic noise.
  • Versatile compatibility
    With a 25 pin D-Sub (DB-25) male connector on one end and a female connector on the other, this cable is highly compatible with a wide range of PC devices, making it a versatile addition to your setup.
C2G Extension Cable - serial / parallel extension cable - DB-25 to DB-25 - 30 m
Serial / parallel extension cable
Shielded
Molded, thumbscrews
Length
30 m
Connector
25 pin D-Sub (DB-25) - male
Connector (Second End)
25 pin D-Sub (DB-25) - female
Shielded
Molded, thumbscrews
Length
30 m
Connector
RoHS
