C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Grey
Quicklinx: 9N1NWS00 Mfr#: 89925
This Booted Shielded Cat6a patch cable is ideal for use with 10GBase-T ports and equipment, such as network adapters, hubs, switches, routers, DSL/cable modems and patch panels, and will protect a high speed 10 Gigabit network connection from noise and electromagnetic interference. For voice/data/video distribution, this cable will handle bandwidth-intensive applications and drastically reduces both impedance and structural return loss (SRL). Each patch cable is fully tested to meet ANSI/TIA 568 C.2 Cat6a component requirements. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality cable and plugs, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded a network installation. Each cable is individually labelled with the length for ease of use.
  • Enhanced connectivity
    The Cat6a Booted Shielded (STP) Network Patch Cable by C2G ensures a reliable connection with its high-quality, gold-plated RJ-45 connectors. These connectors provide a secure link between devices, minimizing interference and maximizing performance.
  • Durable design
    Featuring a robust PVC jacket and aluminum foil shielding, this network patch cable is designed for durability and to protect against external interference. Its construction ensures long-lasting performance and reliability in various environments.
  • High-speed performance
    With American Wire Gauge (AWG) 26 and Category CAT 6a specifications, this cable supports high-speed data transmission. It's ideal for demanding network applications, offering efficient and stable connectivity.
C2G Cat6a Booted Shielded (STP) Network Patch Cable - patch cable - 30 m - grey
Patch cable - CAT 6a
Shielded twisted pair (STP)
Shielding Material
Aluminium foil
Wires per Cable
8 wires
Molded, snagless, stranded
Length
30 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Shielding Material
Aluminium foil
Jacket Material
PVC
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
30 m
Grey
Connector
RJ-45 - male
RJ-45 - male
UL 94 V-0
