C2G 30m Cat5e Non-Booted Shielded (STP) Network Patch Cable - White
Quicklinx: 9N37WS00 Mfr#: 83889
Protect your high speed network from noise and electromagnetic interference when you connect with our shielded Cat5e patch cable. Constructed from high quality cable and plugs, this design minimises Near-End Crosstalk (NEXT) levels. The moulded boot provides extra strain relief and durability. Available in a variety of colours to easily colour-code your network installation.
  • Enhanced connectivity
    The Cat5e Booted Shielded (STP) Network Patch Cable by C2G ensures a reliable connection with its gold-plated RJ-45 connectors, providing superior signal quality and resistance to corrosion.
  • Durable design
    Featuring a PVC jacket material and an American Wire Gauge (AWG) of 24, this patch cable is designed for durability and long-lasting performance, minimizing Near-End Crosstalk (NEXT) for clearer signal transmission.
  • Versatile compatibility
    With T568B wiring scheme and compatibility with PCs, this network patch cable is versatile for various networking setups, ensuring seamless integration with your existing equipment.
C2G Cat5e Booted Shielded (STP) Network Patch Cable - patch cable - 30 m - white
Patch cable - CAT 5e
Shielded twisted pair (STP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, minimised Near-End Crosstalk (NEXT)
Length
30 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
30 m
White
Connector
RJ-45 - male
RJ-45 - male
