C2G 30m Cat5E 350 MHz Snagless Patch Cable - Green
Quicklinx: 6BMJWS00 Mfr#: 83210
Perfect for your home office or a large installation project, enhanced CAT5E 350MHz snagless patch cables from C2G distribute data, voice and video. These cables handle bandwidth intensive applications up to 350MHz and meet all CAT5E TIA/EIA standards. The molded, snag-free boot prevents unwanted cable snags during installation and provides extra strain-relief.
  • Enhanced connectivity
    The Enhanced Cat5E 350MHz Snagless Patch Cable is designed with a T568B wiring scheme and a high-quality PVC jacket, ensuring durable and reliable connections for high-speed data transfer.
  • High-quality transmission
    Featuring a tested frequency of up to 350 MHz and gold-plated connectors, this patch cable ensures high-quality signal transmission with minimal interference, making it ideal for both home and office networks.
  • Universal compatibility
    With male RJ-45 connectors on both ends, this cable is universally compatible with PCs, providing a seamless and secure connection for a wide range of network devices.
C2G Enhanced Cat5E 350MHz Snagless Patch Cable - patch cable - 30 m - green
Patch cable - CAT 5e
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
30 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Green
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
30 m
Green
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
