C2G 30m Cat5E 350 MHz Assembled Patch Cable - White
Quicklinx: 6BLLWS00 Mfr#: 83130
For voice/data/video distribution, this cable will handle bandwidth-intensive applications. Meets all Cat5E TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL).
Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
Constructed from high-quality cable and a shortened body plug, this design minimizes Near-End Crosstalk (NEXT) levels.
  • Enhanced connectivity
    The Cat5e Non-Booted Unshielded (UTP) Network Patch Cable ensures a reliable connection with its high-quality gold-plated RJ-45 connectors, providing superior signal clarity and consistency for all your networking needs.
  • Durable design
    Crafted with a durable PVC jacket and an American Wire Gauge (AWG) of 24, this patch cable is built to withstand rigorous use while maintaining optimal performance. The robust construction ensures longevity and reliability.
  • High-speed performance
    Designed to support a tested frequency of up to 350 MHz, this cable facilitates high-speed data transmission for applications requiring fast and efficient network connectivity, making it an ideal choice for both home and office environments.
C2G Cat5e Non-Booted Unshielded (UTP) Network Patch Cable - patch cable - 30 m - white
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Stranded, uniboot
Length
30 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Stranded, uniboot
Length
30 m
White
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
