For voice/data/video distribution, this cable will handle bandwidth-intensive applications. Meets all Cat5E TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL).
Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
Constructed from high-quality cable and a shortened body plug, this design minimizes Near-End Crosstalk (NEXT) levels.
High-quality connectivity
The Cat5e Non-Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its high-quality American Wire Gauge (AWG) 24 wiring and gold-plated connectors. Designed for durability and optimal performance, the PVC jacket material protects the cable in various environments. -
Enhanced performance
With a tested frequency of up to 350 MHz, this patch cable supports high-speed data transmission. Its T568B wiring scheme and UTP technology minimize interference, providing a stable and efficient network connection for any PC. -
Universal compatibility
Featuring RJ-45 male connectors on both ends, this network patch cable is compatible with a wide range of devices. Its universal design ensures easy integration into existing network setups, making it a versatile choice for various applications.
- C2G Cat5e Non-Booted Unshielded (UTP) Network Patch Cable - patch cable - 30 m - grey
- Patch cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Stranded, uniboot
- Length
- 30 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Grey
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Stranded, uniboot
- Length
- 30 m
- Grey
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 350 MHz
