C2G 2m Value Series High Speed HDMI Cable w/ Ethernet - 10 Pack
Quicklinx: FGHCWS00 Mfr#: 82005?BT
Experience ULTRA HD (4K) displays with this High-Speed HDMI Cable which provides a fast and reliable connection for home theatre or desktop audio video applications requiring high speed HDMI capabilities and video resolutions up to 4K (2160p). This High-Speed HDMI Cable supports the latest HDMI features including Ultra HD, 4K at 50/60 (2160p), up to 32 audio channels and wide angle theatrical 21:9 video aspect ratio and is compatible with any modern Laptop, Chromebook, HDTV or gaming consoles, including Sony PlayStation 4 (PS4) and Microsoft Xbox ONE. The Ethernet capabilities of the cable allow users to connect multiple Ethernet-enabled HDMI devices through a single Ethernet connection. This fully-functional, high bandwidth cable is tested to perform at industry standards and is backed by a lifetime warranty. Note: Both the source device and display must support a HDMI feature in order to pass that particular feature through this cable.
  • Enhanced connectivity
    This HDMI cable with Ethernet combines video, audio, and data streams into a single HDMI cable, providing an all-in-one connectivity solution for a streamlined user experience.
  • Durable build quality
    Featuring a durable PVC jacket and molded construction, this cable is designed for longevity and robust performance, ensuring your connections remain secure.
  • High-quality video support
    Supports 4K UltraHD resolution, offering stunning visual clarity and detail for an immersive viewing experience, whether you're watching movies, gaming, or engaging in high-definition video conferences.
  • Improved audio and video control
    Equipped with HDMI CEC support, this cable allows for integrated control and communication between devices, enhancing your control over audio and video settings.
  • Reliable Internet connection
    With HDMI Ethernet Channel (HEC) technology, this cable facilitates a reliable Internet connection between devices, eliminating the need for separate Ethernet cables.
C2G 2m High Speed HDMI Cable with Ethernet - 4K - UltraHD - HDMI cable with Ethernet - 2 m
Cable
Length
2 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
HDMI Ethernet Channel (HEC), HDMI CEC support (Consumer Electronics Control), moulded
Microsoft Surface Hub 2S 50"
Cable Type
Jacket Material
PVC
Length
2 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
Limited warranty - lifetime
