Experience ULTRA HD (4K) displays with this High-Speed HDMI Cable which provides a fast and reliable connection for home theatre or desktop audio video applications requiring high speed HDMI capabilities and video resolutions up to 4K (2160p). This High-Speed HDMI Cable supports the latest HDMI features including Ultra HD, 4K at 50/60 (2160p), up to 32 audio channels and wide angle theatrical 21:9 video aspect ratio and is compatible with any modern Laptop, Chromebook, HDTV or gaming consoles, including Sony PlayStation 4 (PS4) and Microsoft Xbox ONE. The Ethernet capabilities of the cable allow users to connect multiple Ethernet-enabled HDMI devices through a single Ethernet connection. This fully-functional, high bandwidth cable is tested to perform at industry standards and is backed by a lifetime warranty. Note: Both the source device and display must support a HDMI feature in order to pass that particular feature through this cable.
HDMI Feature Note
Both the source device and display must support an HDMI feature in order to pass that feature through this cable -
Multi-Stream Audio
Simultaneous delivery of multi-stream audio to multiple users (up to 4) -
Wide Angle Support
Support for the wide angle theatrical 21:9 video aspect ratio -
Dynamic Synchronization
Dynamic synchronization of video and audio streams -
CEC Control
CEC extensions for control of consumer electronics devices through a single control point -
Compatibility
Compatible with both Sony PlayStation 4 (PS4) and MicroSoft XBOX ONE consoles. It's also backwards compatible with PlayStation 3 (PS3) and XBOX 360 -
Black -
Warranty
Lifetime -
Connector 1
(1) HDMI Male -
Connector 2
(1) HDMI Male
- C2G 2m High Speed HDMI Cable with Ethernet - 4K - UltraHD - HDMI cable with Ethernet - 2 m
- Cable
- Length
- 2 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- HDMI Ethernet Channel (HEC), HDMI CEC support (Consumer Electronics Control), moulded
- Limited lifetime warranty
- Designed For
- Microsoft Surface Hub 2S 50"
- Cable Type
- Jacket Material
- PVC
- Length
- 2 m
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- Limited warranty - lifetime
- Designed For
