C2G 2m USB A Male to Micro A Male
Quicklinx: DWQTWS00 Mfr#: 87362
Connect to mobile phones, GPS systems, PDAs, OTG devices and digital cameras by using the micro-USB connection on your computer or other USB device. Its small form factor is ideal for today's compact portable devices while easily transferring data or charging your device at a high transfer speed.
C2G - USB cable - USB to Micro-USB Type A - 2 m
USB cable
USB On-The-Go
Length
2 m
Connector
4 pin USB Type A - male
Connector (Second End)
5 pin Micro-USB Type A - male
USB / USB 2.0
USB cable
USB On-The-Go
Length
2 m
Connector
USB / USB 2.0
