This USB 3.0 (USB 3.1 Gen 1) USB-C to USB-Micro B cable is the perfect solution for connecting a smartphone, tablet, or other device that has a USB-Micro B port to a computer, tablet or other device that has a USB Type-C port up to 2 metres away for USB 3.0 (USB 3.1 Gen 1) communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 3.0 (USB 3.1 Gen 1) cable and differentiated from other cables which may support a different feature set. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. This cable supports a data rate up to 5Gbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging.
Efficient charging and syncing
The 2m USB 3.1 Gen 1 USB Type C to USB Micro B Cable is designed to provide efficient charging and syncing capabilities. With its American Wire Gauge (AWG) of 24/30, this cable ensures efficient power delivery and data transfer between devices. -
Durable design
Featuring color-coded connectors, a nickel-plated shell, and a gold-plated connector, this cable is built for durability and long-lasting performance. Its robust design prevents corrosion and ensures a secure connection every time. -
Universal compatibility
Designed to be compatible with PC, this USB-C cable offers a versatile solution for connecting a wide range of devices. Whether you're connecting to a smartphone, tablet, or hard drive, this cable ensures a reliable connection.
- C2G 2m USB 3.1 Gen 1 USB Type C to USB Micro B Cable - USB C Cable Black - USB-C cable - 24 pin USB-C to Micro-USB Type B - 2 m
- USB-C cable
- Sync and charge, colour-coded connectors, nickel plated shell
- Length
- 2 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 10 pin Micro-USB Type B - male
- USB 3.0/ USB 3.1
- Black
- Limited lifetime warranty
- USB-C cable
- American Wire Gauge (AWG)
- 24/30
- Plated Connector
- Gold
- Length
- 2 m
- Black
- Connector
- USB 3.0/ USB 3.1
